Old 04-12-2007, 04:02 PM   #1
Question
Unsoldering - Part 2
are there special pliers whose one jaw fits inside a 1/2 or 3/4 pipe and the other on the outside so i don't have to grip on the outside and jeopardize bending the pipe out of shape ?
e.g. needle-nose pliers would do it if the handles were longer and the jaws were mildly curved so as to not flatten the portion of the pipe where the grip takes place.
Old 04-12-2007, 04:29 PM   #2
zel
Send a message via AIM to zel
If that end of the pipe is in good shape, can you just add on to it with a male-to-male copper joint? (not sure of the proper name)
zel is offline   Reply With Quote
Old 04-12-2007, 04:32 PM   #3
Exclamation
because it is a 3/4 tee and the one i want to unsolder has an adapter to 1/2 pretty much right after the tee and i want it to continue to be 3/4 for a few more feet because i am making some new outlets.
Old 04-12-2007, 04:44 PM   #4
zel
I see. If you absolutely cant break the solder loose, just cut out a larger section and replace it with the correct size tee.
Old 04-13-2007, 09:07 AM   #5
Yes. You may need to just cut back on the other 3/4 lines and install a new tee with unions.
"The hard way is the easy way."
Jeekinz is offline   Reply With Quote
Old 04-13-2007, 12:50 PM   #6
http://www.amazon.com/gp/product/cus...&n=228013&s=hi
Old 04-13-2007, 12:52 PM   #7
taking copper pipe out from existing position without cutting sometimes is real challenge, been there before... sometimes even taking dry fitted copper pipe out is difficult, not to mentioned soldered... if it is too difficult... cutting pipes sometimes is a better option
KUIPORNG is offline   Reply With Quote
Old 04-13-2007, 02:18 PM   #8
Journeyman Plumber
Ron The Plumber's Avatar
One thing about unsoldering is, free of water content, I believe there was water on the heated point causing the fitting to not get hot enough, the trick is heat and plenty of it, use mapp gas, burns hotter and can even heat fast enough to boil water out of the fitting if it's there. Once you see the solder spit from the fitting cup, keep the heat on it till you fully extract the pipe.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 04-13-2007, 08:12 PM   #9
jproffer's Avatar
Also, to follow up from your "part one" thread: You just cut the pipe off with a hacksaw (or whatever you cut it with) and there's only a few inches left, correct? So why does it matter if it gets bent up?
That said, Ron's absolutely correct...it should just come right out...IF you have it hot enough.
jproffer is offline   Reply With Quote
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 09:48 AM
My house is a project...Part II "Deck Evolution" tigerbalm2424 Project Showcase 21 07-24-2008 11:37 AM
DecoRez two part system Questioner Introductions 4 12-10-2006 12:14 PM
Furnace Problems? Part 2 MCSE HVAC 9 11-30-2006 10:25 PM
Cost to texture part of a room ConstantChange Painting 3 09-27-2006 06:26 PM
