Unremovable Toilet Seat, Please Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2010, 07:46 PM   #16
the Musigician
DangerMouse's Avatar
J B Weld that bad boy....
DM
Old 12-05-2010, 10:46 AM   #17
Homerepairguy's Avatar
Rewards Points: 998
Originally Posted by Oliver126 View Post
Looks like I'll have to give that a shot, what type of epoxy putty am I looking for in particular?
Grease the screw when you do the epoxy thing. Then at least you'll have a chance of having a removable screw.
HRG
Homerepairguy is offline   Reply With Quote
Old 12-05-2010, 11:55 AM   #18
40+yrs Paint Trades
Here's a trick you may want to try.
Clean out the hole and insert JB Weld to fill. After cure drill out hole a insert a "helicoil" of matching thread and diameter to a toilet seat bolt.
Or, Clean out the hole and insert JB Weld to fill. Before cure insert toilet bolt on a matching SS nut into the JB. (Wax the bolt prior or spray with hair spray as a release agent.) After cure unscrew bolt and install toilet.
hoz49 is offline   Reply With Quote
Old 12-05-2010, 12:16 PM   #19
the Musigician
I'd fill it (let it harden completely) then drill it, then tap it. You can do that with JB. Po)
DM
Old 12-05-2010, 12:54 PM   #20
40+yrs Paint Trades
Who designed this blind hole toilet seat attachment anyways? Seems like a very bad idea.
Old 12-05-2010, 01:25 PM   #21
the Musigician
Look at the very first post.... Kohler.
DM
Old 12-05-2010, 11:30 PM   #22
I ended up just using epoxy putty to cement the new seat in place, had already done so before reading all these great ideas you guys posted. So... yea I'm stuck w/ a pretty permanent seat.
Which is why, i went out and returned the $20 plastic seat I got, and went all out on the best one I could find, since it'd be there to stay.
Its wood, so it doesn't get chillingly cold in the winter (programmable thermostats means heat gets pretty stingy while I sleep). The finish is supposed to be anti-bacterial. And the hinges are stainless steel, and close slowly (they're called whisper-quiet by the packaging).
Thanks for everyone's help on this!
Oliver126 is offline   Reply With Quote
Old 12-05-2010, 11:47 PM   #23
Rewards Points: 150
hmmmmmmmmmm
Sorry I did not see this earlier... I had this same exact problem at a customers house... They called me to replace toilet seat... Stuck screw driver gave a turn and it just spun freely... tried other and it was in there TIGHT! They then said I must have broken the other one by applying to much pressure!!! So when I got the other one out they said they were going to sue me if I could not fix it. after arguing for 10 minutes they admitted they broke it and I was nice enough to toss Toggle bolts in it
Docwhitley is offline   Reply With Quote
Toilet leaking from seat mounting hole jrpoole59 Plumbing 11 05-05-2010 10:25 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet seat slipping and coming loose. zunebuggy Plumbing 1 09-07-2009 03:43 PM
Self lifting toilet seat babycody Plumbing 10 06-27-2009 12:51 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
