Universal Tub Diverter Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2006, 10:54 PM   #1
Question
universal tub diverter faucet
I truly could use some help here! My bathroom is being redone by some friends with good basic dry wall skills, but not too up on plumbing. I have an old house, and I have a 1/2 inch threaded pipe coming out from the wall, and when they tried to install it, the thing is leaking. The person at the hardware store told me to remove the brass adaptor (which I did), the directions on the back say to take out part b, the 3/4 adapter. Is the 3/4 part the plastic long piece, and I need an allen wrench to take it off, or...? Help..If I have to make too many more trips to the hardware store, I'm going to go nuts.
faintchimes is offline   Reply With Quote
Old 02-15-2006, 12:04 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Did you use teflon tape of the male threads of the pipe coming out of the wall?
If not, wrap 2-3 flat wraps of teflon tape clockwise only on those threads and then screw on the tub spout.
You may have to retape it a couple of times to get it to set upright without leaking, but you should be able to screw it on by hand (or snug it around with a wrench over a washcloth, or use a strap wrench, to keep from marring the spout surface).
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-15-2006, 08:17 AM   #3
They did use tape, but we are going to try again, I'll let you know how it goes. Thank you.
Old 02-16-2006, 07:36 AM   #4
It's working!
Got to take a shower this morning. Wow! Should have a toilet by the end of the day, as well..
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 08:12 PM
Repair outdoor faucet? mx13 Plumbing 3 04-09-2007 06:08 PM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 04:56 PM
Faucet replacement rondo Plumbing 2 12-03-2006 12:49 PM
Faucet Sprayer Oswald Plumbing 2 03-29-2006 02:10 PM
