Union Thread Sealing - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2008, 10:50 PM   #1
Question
I recently installed an Indirect Water Heater and it came with union fittings on all inlets and outlets. I have had problems getting two of the fitting to seal. I did not use dope or tape as I thought it was not necassary on these fittings. Does anyone know what the best practice is for sealing these unions? Should I simply load it up with dope and/or tape?
dave2008 is offline   Reply With Quote
Old 06-13-2008, 11:41 PM   #2
Registered User
Termite's Avatar
Where the union connects into the pipes, you need to use a few wraps of teflon thread tape. I'm assuming they're conventional unions with tapered "NPT" threads. The threads in the union's internal coupling (where the union comes apart) do not require thread tape or sealant. Actually, tape or sealant will prevent the union from sealing.
Old 06-14-2008, 12:59 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If your mating surfaces don't match up really really really really really really close, almost perfectly, you probably will have problems.
We've only used dope in instances where we're resealing an old union.
Are the unions soldered onto the water heater, or are they thread on type unions?
If they thread onto a nipple on the water heater, you do need to wrap tape on THAT joint.
Journeyman Plumber
Old 06-14-2008, 10:45 AM   #4
Union faces and the nut threads should not need any sealant or pipe compound. These are machined surfaces. Sounds more like a bad fit-up between the piping and one of the union halves.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-14-2008, 10:45 AM   #5
Question
The union is a straight thread Joint and the fittings are soldered into the Water Heater. So, if the mating surfaces are not really close (and I'm gonna assume they were not since they leak), is there another option other than unsoldering the fitting and installing a new one?
Old 06-14-2008, 01:16 PM   #6
Doing it myself
Alan's Avatar
If you unscrew the unions, the halves should line up almost perfectly, and almost be touching. They shouldn't pull away from the other half and be at some odd angle...
You shouldn't need a new union if this is the case, you might need to extend or shorten your water lines.
can you post a picture of the heater/unions/waterlines connecting ?
Journeyman Plumber
Sealing Threads on water feed in shower MickeyC Plumbing 1 01-17-2008 01:32 PM
Water heater hot outlet union leaking dog193 Plumbing 4 01-10-2008 10:07 AM
leaking thread connect bobcatnj Plumbing 2 01-06-2008 11:07 AM
