Union On A Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2011, 01:26 PM   #1
union on a gas line
should i put rectorseal on a union on a gas line? if so, where on the union?
joezizz is offline   Reply With Quote
Old 08-02-2011, 01:33 PM   #2
fabrk8r
fabrk8r's Avatar
There are many opinions. Here is a link to another thread on this subject.
Black pipe gas unions: install "wet" or "dry"?
And another:
Black pipe unions for gas?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 09:09 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
