Union Fitting For Gas - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2008, 03:56 PM   #1
Rewards Points: 270
Union fitting for gas
Could you tell me if I put TFE paste on the outer most thread. The gas line is 3/4", I mean the large outer most thread which allows you to tighten both pipes together. My thought is no because it is a flare or compression fitting.
pcampbell is offline   Reply With Quote
Old 03-05-2008, 04:26 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Not needed but you can if you like.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-06-2008, 10:26 AM   #3
It is not necessary but could aid in loosening it in the future if needed. I got in the habit of using Never-seez on steel pipe unions for just this reason.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Replace PEX fitting with Shark Bite Push Connector? larrybr45 Plumbing 3 01-27-2008 02:01 PM
Water heater hot outlet union leaking dog193 Plumbing 4 01-10-2008 09:07 AM
Leaking Sink fitting seajay590 Plumbing 3 09-13-2007 08:28 PM
which way to cut baseboards for inner angle fitting? KUIPORNG Carpentry 22 05-30-2007 02:26 PM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 07:03 AM
