Uninstalling Basin Hardware - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2015, 06:04 AM   #1
Uninstalling basin hardware
I am trying to remove all basin hardware and plumbing underneath. I have been able to get the pipes d/c and the taps removed, but cannot loosen the t-pipe or the brace on top of the basin.
Obviously I only need to loosen one to slip the whole lot out - obviously my brute strength isn't working. Wondering if one is easier than the other?!
Kind of stupidly pulled it all apart as my husband is away - now obviously have no water, would prefer help instead of ringing him in utter defeat! :/
Miss G is offline   Reply With Quote
Old 04-14-2015, 06:54 AM   #2
DIY staff
Rewards Points: 5,778
They are not all alike--so a picture of the faucet would help--or a link to the manufacturer--
If this is a 'spread' faucet--seperate handles and spout--those are fastened from the top of the sink--the fancy trims hide the attachment nuts or C-clips.
oh'mike is online now   Reply With Quote
Old 04-14-2015, 07:18 AM   #3
Thank you, no clue on manufacturer.
Old 04-14-2015, 07:26 AM   #4
DIY staff
Just as I suspected--that brass nut needs to be removed and the valve will come out from below.
That is a corroded thing---if you cant get it to turn loose---you can break the nut---a drill bit--placed against the threads and the top of the nut --drill into the nut in a couple of places---snap the nut by wedging a screw driver into the hole you made--
jmon (04-14-2015)
Old 04-14-2015, 07:30 AM   #5
Amazing, thank you! I will give that a go!
Old 04-14-2015, 08:12 AM   #6
Rewards Points: 4,992
+1
It probably won't help any, it looks too corroded. You can try some pb blaster let it soak for awhile, give it a few taps, try again.
jmon is online now   Reply With Quote
Old 04-14-2015, 08:03 PM   #7
Rewards Points: 3,454
Use a mini hack saw and cut the big brass nut. Once you get it close to through place a flat head screw driver in the cut and twist it should snap the nut. We are talking about the big flat nut by the sink.
Old 04-14-2015, 10:37 PM   #8
I ended up drilling two holes into the bottom nut, and snapping it that way!
One down, one too go. I've decided this will be my last DIY plumbing task. EVER. I had to fight the urge to get the grinder and grind the whole thing away!
Thanks for all your help.
The Following User Says Thank You to Miss G For This Useful Post:
jmon (04-15-2015)
Another Sump basin question from a noob... omne51 Plumbing 5 08-25-2012 03:20 PM
Sump Pump Basin jonathan123 Plumbing 2 08-21-2011 08:31 PM
Sump Basin Install Considerations Fire4Effect Building & Construction 3 08-05-2009 04:30 AM
Catch Basin sebas54 General DIY Discussions 2 07-13-2008 09:38 PM
