Unidentifiable Pipe/vent In Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2005, 09:42 AM   #1
Unidentifiable pipe/vent in bath
I've got an upstairs bath that I'm ready to floor with ceramic; the bath has not been used since I've owned the house ( 12 years ). If you sit on the potty and stretch your leg out, you'll put your foot on a ~4" round screwed-on floor plate which is a cover for a vertical flush-mounted pipe. This bath is the highest in the house, so I'm wondering if it's a vent. The house was built in 1950. I"d like to start putting down the wonderboard, but I'm 'wondering' if I should cap it off or cutout the wonderboard and tile and keep it intact. It sure looks crummy and I'd like to be rid of it; I’m afraid my small kids will discover it and drop ‘fun things’ down the pipe, but the last time I removed something that I didn't comprehend, it was the deadend hot and cold 'shock absorbers' ( ~12" of closed-end pipe at the highest point ) to prevent water hammer and I'm still thumping myself in the head for that one.
Hobiedog is offline   Reply With Quote
Old 12-02-2005, 06:33 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If it was a vent, I doubt that it would be capped off. It could be a stubbed drain pipe, however, tied into your drain system.
It may be a drain connection for a sink, tub/shower, or floor drain. Remove the cap and see if the pipe is 1.5"-2" or has a trap in it (flashlight look). If it is, that's probably its original purpose.
You can always put your ear to it, and have someone run water downstairs to see if you can hear it rushing through the pipe, to see if it's tied in to the rest of the drain/waste/vent system.
Mike
Mike Swearingen is offline   Reply With Quote
Bath Fitter Opinions..?? GoodoleBob Remodeling 31 02-25-2010 10:25 AM
Fractures in the bath tub HAASEMAN2003 General DIY Discussions 2 03-27-2007 10:32 AM
Bath remodel wiring Nhrafan Electrical 14 03-23-2007 06:53 PM
bath floor nailfun Plumbing 5 02-20-2007 11:35 PM
painting filled crack in bath zoodemon Painting 7 10-06-2006 05:15 PM
