Old 12-30-2011, 06:06 PM   #1
unhooking water filter dohickey
I'm redoing the kitchen. I want this filter thing out.If i take this brass hook up thing off will water shoot out of the hole it made? The shut off tap is above this hook up. How do i take this off properly? Thanx in advance. I tried to add a pic,...
jimbobber is offline   Reply With Quote
Old 12-30-2011, 06:17 PM   #2
Master Plumber
Javiles's Avatar
1 you could leave that saddle clamp valve on the pipe which I don’t recommend and put a small brass cap on it.
2 the correct way ,cut the copper and solder in a new small section. Whatever you do, do not attempt to cover the hole with a lead patch.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 12-30-2011, 06:30 PM   #3
Lightfoot's Avatar
answer to your question is YES, water will come out of the hole it made. It looks like a saddle valve. Replacing that section of pipe where the hole is would be the only thing i could suggest.
edit: javiles already nailed it. He likely types with more than two fingers.
Lightfoot is offline   Reply With Quote
Old 12-30-2011, 06:36 PM   #4
#1 Why do you want to get rid of it?
Other then it being installed wrong in the first place but could be easly corrected it can end up saving you money instead of buying bottled water.
Old 12-30-2011, 07:06 PM   #5
how much room below cuppling under saddle valve....show more pitcures lower and one higher...
Old 12-30-2011, 08:01 PM   #6
Master Plumber
Javiles's Avatar
Nope 2 fingers and spell check, I have yet to meet an old plumber that can type with more than 2 fingers.
The Following User Says Thank You to Javiles For This Useful Post:
plummen (12-30-2011)
Old 12-30-2011, 08:27 PM   #7
retired elect/hvac/plumb
plummen's Avatar
And everybody knows which finger we use to type with!
plummen is offline   Reply With Quote
Old 12-30-2011, 08:31 PM   #8
plummen's Avatar
Yes you could put some teflon tape on the threads and screw a cap on that fitting and probably never have an issue with it
If you do decide to cut it out id do it below that existing coupling in your picture and just run new copper all the way up to a new shut off for faucet.
As far as the filter id just install an inline whole house filter with a ball valve on each side just past your water meter where service enters house
Water Filters in boil water order wiz561 Plumbing 2 11-30-2011 08:41 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Bypassing Refrigerator Water Filter foiler Appliances 2 01-12-2009 09:06 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
