Old 06-20-2011, 01:03 PM   #1
Unfinished Basement build out
Guys,
I have an unfinished basement and planning to finish it, with a small kitchen and bathroom in mind. They will be on opposite walls though, that is where I am stuck.
I have attached pictures of what I'm trying to do.
I'll be using a saniflo pump for the bath which accepts sink/toilet/shower and discharges behind the toilet.
What I need help with is to figure out how to tie into the sewer pipe. The utility sink will be moved, so should I consider using that as my discharge outlet? How would I vent it?
Also, over to where I'll be moving the utility sink has a cleanout cover. How can i tap into that to convert it into a discharge for the utility sink? Would a bushing work?
Finally, i need to run a pipe along the front wall and somehow tap into the sewer line that runs parallel to the side wall. What advice do you guys have to get that done? I'm considering a mini vent for the sink, because I don't have any vent pipes over there.
Thanks in advance.
Rocky
roc1479 is offline   Reply With Quote
How to duct an unfinished basement wileefox HVAC 1 05-24-2011 05:32 AM
Insulating basement - questions jtmann HVAC 7 11-19-2010 04:20 AM
Inexpensive way to section off unfinished basement? eastie Building & Construction 0 11-06-2009 05:47 PM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 10:53 AM
Wiring Unfinished Basement Renovator Electrical 12 04-25-2006 10:36 AM
