i messed up the angle on a 45 degree elbow. i've already chopped it out.
to redo means chopping out quite a bit of plumbing, as there are a bunch of 45s and a T glued together with no pipe.
is there any way to remove the glued-on piece within the hub of the intact 45, and redo it, or is the only way to chop it all out back to the straight pipe. pretty sure i know the answer here...
thanks
thanks
