Underslab Leak Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-13-2015, 01:11 PM   #1
Rewards Points: 4
Underslab leak help
What would you do? Should I remove non load bearing wall and jack up the floor to make repairs?
gspace7 is online now   Reply With Quote
Old 04-13-2015, 02:46 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 3,334
Underslab leak help
Ayuh,.... Bust a hole in it, 'n see how far/ which way yer goin', 'm play it by eye,...
If the wall is in the way, ya gotta move it,...
Bondo is online now   Reply With Quote
Old 04-13-2015, 06:13 PM   #3
Rewards Points: 1,102
Underslab leak help
yep open it up alittle to see where it is leaking at...should have been sleeves around copper pipe comming up through concrete...might be right there..
Old 04-13-2015, 06:49 PM   #4
Rewards Points: 4
Underslab leak help
Thanks guys. More work than I was hoping for.
Old 04-13-2015, 06:52 PM   #5
Underslab leak help
if you know where the line is going..maybe you could run new line overhead to it ...and forget about line under floor
Old 04-13-2015, 07:25 PM   #6
Rewards Points: 4
Underslab leak help
I would like to do that but don't know where the line under the slab runs. There's at least two other locations using underslab plumbing.
Any tricks to locating where these lines run?
Old 04-13-2015, 07:29 PM   #7
Rewards Points: 2,830
Underslab leak help
I would suggest you plan on a total repipe of your waterlines. If it is leaking once underground it will leak again. Better to bite the bullet now. Cut the floor and run new pex water to all areas you need to.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Javiles (04-14-2015)
Old 04-14-2015, 06:35 AM   #8
Rewards Points: 1,126
Underslab leak help
Funny I was thinking the same thing before I read your answer.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 04-14-2015, 01:19 PM   #9
Rewards Points: 4
Underslab leak help
Temporary fix by installing Sharkbite ball valves. Through a series of cutting holes in the drywall I have located where the water enters the slab. Unfortunately it is the hot line that is the culprit and having it off cuts off all hot water in the house except for the upstairs master bath sink.
It does however remove the leaking from the slab.
Done for today. However need to run lines off the hot to the fixtures that need it.
I agree with the majority of the posters here about abandoning everything under the slab.
We used to have underslab ducting for heat/ac and now it's upflow and overhead.
The Following User Says Thank You to gspace7 For This Useful Post:
ben's plumbing (04-14-2015)
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 08:47 PM
Slab leak advice needed! Help MsTFT Plumbing 23 01-31-2013 03:34 PM
Mystery - leak or no leak turness Plumbing 4 01-12-2013 07:46 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
