Underslab Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2010, 10:27 PM   #1
Question
Underslab Copper
I've had two hot water rolled copper pipes develop leaks under slab within 6 months of each other. So I've routed new piping overhead in the basement for the three hot runs and abandoned the hot water underslab piping. Should I be concerned about the cold lines developing leaks and go ahead and re-route those overhead as well before I finish remodeling the basement? There was no dieelctric union at the water heater. I'm hoping that the cold water lines have not eroded like the hot water lines obviously have. The underslab lines are about 34 years old. I believe I know the answer and it will be a tremendous amount of work now.... but I suppose that would far less than if it sprung a leak soon after I finish the basement out. Thanks for any insight the experienced folks might be willing to share with me.
Brianklink is offline   Reply With Quote
Old 01-29-2010, 06:37 AM   #2
Rewards Points: 5,336
It will leak right after you finish the basement if you don't do it now. But you already knew that.
Ron
Old 01-29-2010, 06:47 PM   #3
Nice I think Ron hit it right on the head Theat Darn Murphys Law !! Run them now and sleep good tonight .
arcticbouncer is offline   Reply With Quote
Tags
dieelectric union , hot water piping , rolled copper , underslab leaks
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
pex vs copper piping sizes dichroic Plumbing 6 07-28-2009 09:35 AM
Installing copper gutter to replace some concrete tiles whattodo Roofing/Siding 2 07-28-2009 07:28 AM
is a US penny in scrap worth more than US$0.01 ? amakarevic Off Topic 9 10-25-2008 09:11 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
