Old 08-26-2008, 10:05 PM   #1
Undermount Bath Sink Dropped
Help!! My undermount in the bath separated and dropped a half inch or so. It's a porcelin or china sink (bonded with something) to a marble vanity top. There are no clips or slots for clips on the underside of the vanity top.
What's the best way to remount this thing securely???
capt2 is offline   Reply With Quote
Old 08-26-2008, 11:19 PM   #2
Moderator
Termite's Avatar
It was glued to the underside of the counter with no hardware to retain it? Did you have it installed by a "professional" countertop installer or a plumber? If so, you need to give them a call.
Normally with stone/granite/marble tops, undermount sinks are retained by a few clips that are inserted into milled pockets in the underside of the top, as you mentioned. They're siliconed as a good measure, but probably more for the purpose of sealing leaks.
I doubt that silicone adhesive would sufficiently adhere the sink to the underside of the counter. I can't think of anything else that might be appropriate for this application. Perhaps a countertop company in your area could recommend a better product.
Old 08-27-2008, 04:20 AM   #3
Right, there no clips or milled pockets for them. And the actual installer person is unknown. So what can I do to hold the sink up at this point??
Old 08-27-2008, 07:28 AM   #4
Whatamess
You may want to take to top and sink to a shop that does this and have it reattached. Never did any myself but you may be able to get some epoxy that will hold it. Either way you have to turn the top upside down to repair it.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-27-2008, 11:35 AM   #5
Moderator
Termite's Avatar
Barring removal of the top, you might be able to frame some wood supports under the sink's sides to bear its weight...Essentially wedgeing it in place. Combined with some silicone, it would probably support it just fine.
It would certainly not be an ideal installation or a selling feature, but would be an inexpensive and easy way to get your sink back in business until you can fix it correctly.
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
pipe size for tub, floor, and bath sink drains amakarevic Plumbing 2 07-25-2007 08:29 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Need Help with double bath sink trap after remodel cmontel Plumbing 13 12-03-2006 07:06 PM
