Underground Water Line To Detached Garage - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2013, 03:52 PM   #1
underground water line to detached garage
Hey guys
i live in Vancouver BC
I'm running an underground water line from my house to my detached garage. Its about a 30 foot run.
I was wondering what you guys thought would be the best pipe for me to use and wether I should sleeve it or not? If so, what should I sleeve it in?
right now i'm leaning towards using PEX and sleeving it in some 'BIG O' drainage pipe.
Would love to get your guys' opinion
thanks in advance
OnlyOneKeano is offline   Reply With Quote
Old 05-20-2013, 04:40 PM   #2
Rewards Points: 14,312
Pex will be fine but it's going to need to be bured below the frost line.
Only place it needs to be sleeved is where it runs through concrete.
MTN REMODEL LLC (05-20-2013)
Old 05-21-2013, 09:47 PM   #3
Rewards Points: 152
Agreed, and make sure you bed the line with lots of sand.
burnt03 is offline   Reply With Quote
Old 05-22-2013, 07:05 PM   #4
Rewards Points: 2,108
Cover the entire pipe with sand...
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Need help on running gas line to detached garage gjones Plumbing 2 05-22-2012 06:30 AM
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 01:24 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
