Underground Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-23-2010, 06:06 PM   #1
Does anyone have any ideas/suggestions on how to locate an underground water line that is in black plastic pipe? Besides digging a bunch of test holes
Flavio is offline   Reply With Quote
Old 07-23-2010, 06:12 PM   #2
Owner
LateralConcepts's Avatar
Plastic water piping cannot be located.
There is a way, but not easy or advisable actually.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-23-2010, 08:02 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
digging one really big hole.
explain why you need to do this. There might be something somebody can add to help you.
are you sure there wasn't a tracer wire run with the line? that would be a wire run right along with the water line so you could use a tracer to find it.
Old 07-23-2010, 08:27 PM   #4
The reason that I want to locate the line is to install a hydrant midway between two others. There was no tracer wire installed.
Old 07-23-2010, 08:51 PM   #5
you could try to find the line by "witching" it. Use two metal wires bent into an L shape. hold the short end in your hand loosely. ( one in each hand) walk the area you think has the water line. when the rods cross you are over the water line. ( This does not work for everyone. try several of your neighbors also.
merle is offline   Reply With Quote
Old 07-23-2010, 09:26 PM   #6
nap
You talking to me?
nap's Avatar
well, plumbers are usually cheap SOB's so they probably ran a pretty straight shot from one to the other. Obviously if there were any obstructions in the way at the time they would have had to go around it.
merle makes a good suggestion. I know people that claim they are good at it. Now, one of those guys figured he would show some guys just how good he was and missed the line by way more than anybody would accept as a tolerance so..
It is what it is.
just kidding about the plumbers. They aren't actually that cheap.
they are just so lazy it would take more work to dig a trench that wasn't straight.
If it were me, I would scratch a line between the hydrants and where you want to put a hydrant, start digging a hole. Then if you don't find the pipe in the depth you suspect it might be, start turning that in a trench perpendicular to the scratched line.
In other words, no, there really isn't an easy and sure way to find the line.
is this a private line? If so, is there any way you could feed a wire through the line from hydrant to hydrant? If so, you do that and get a tracer and away you go.
Old 07-23-2010, 09:38 PM   #7
Owner
That was going to be my not easy or advisable method. Depending on the size of the pipe and how whether it's a straight shot or not, you could run a fish tape, and locate it with a 65khz transmitter, but too many likely problems could occur
Lateral
(208) 818-8241
Old 07-23-2010, 09:46 PM   #8
Rewards Points: 1,910
Start where you want the new hydrant and dig a trench from that location towards and perpendicular to a straight line between the two existing hydrants. You should have no wasted digging that way.
Old 07-24-2010, 08:45 AM   #9
Just call me Andrew
Rewards Points: 1,020
Related question...I am installing a sprinkler system in my lawn with black polyethylene pipe. Should I install a tracer wire as I lay the pipe?
What is a tracer wire made of? Is it connected to some electrical source or just a piece of wire in the ground?
If a mod thinks this should be in its own thread, please split it off. Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 07-24-2010, 11:53 AM   #10
Doing it myself
Alan's Avatar
Rewards Points: 2,086
UNLESS we were going to put PVC in there, and the trench was 'to be dug by others' and when we got there it was about as straight as a lawyer, so we decided to use poly instead to make it easy.
Journeyman Plumber
Old 07-24-2010, 05:34 PM   #11
Thanks to you all for your suggestions. It sounds like the simplist way to try to locate the pipe is to try the witching method If it works I will let you know. If it doesn't work for me, quess I will start diggin again.
Hey Nap, is that some kind of a dog by your name?
Old 07-24-2010, 05:42 PM   #12
nap
You talking to me?
nap's Avatar
it's a llama or alpaca. just some pic I found in the etherworld that seems to fit me.
Underground Electrical Line and water line. Randell Tarin Electrical 11 09-18-2011 08:19 AM
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 09:20 AM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
