Underground Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2010, 09:57 AM   #1
Underground plumbing
I just bought a lot and am getting ready to build and ran into an issue. I was hooking into the underground city sewer line when I noticed that my underground 3 1/2 " line that is stubbed up to service my lot continues on past my lot then services 3 other homes (that I know of). Can multiple homes be on one 3 1/2'" line ? This does not seem right to me but I am not a plumber at all.
warnerww is offline   Reply With Quote
Old 03-02-2010, 10:31 AM   #2
Send a message via Skype™ to GarageDoorCente
A 4" Line is sufficient per Washington code, for 2 "families". We have built many duplexes and we use 1 6" service, but we could use a 4". We do these duplexes back to back, so we have 2 6" for every unit, but smaller is available. We installed a 2" pipe for 2 houses, but it had a grinder and pump on the outlet for the duplex, that way our sewer line could make it to the city's without running about a quarter of a mile, to get to the only downhill place. If this is a normal service, it had to be inspected to be put in(it's a little obvious when someone is digging down to a sewer) and was approved for the job, but it doesn't seem correct to me to have 3 on that small of a pipe, even though no person poops that much
GarageDoorCente is offline   Reply With Quote
Old 03-02-2010, 09:14 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm confused. 3.5" ? ? ? I've never heard of such a thing.
standard sizes are 1.5, 2, 3, 4, 6 and on up.....
our code defines sizing requirements for 1.25, 1.5, 2, 2.5, 3, 4, 6, 10 and larger
You can't readily buy the 2.5 and 1.25 at least around here. Odd size if it's really 3.5
If you're measuring the outside diameter of ABS or something similar, it would measure ~3.5, but we go by inside diameter.
3" will only take 3 toilets on a horizontal line per our local code. Check with yours to be sure.
Please verify the size of your pipe too.
Journeyman Plumber
Old 03-02-2010, 11:08 PM   #4
OK I dug down further and I was wrong ( I hate that). The pipe is 6" and it serves 4 other single wide trailer rental homes with one bathroom. The town is very small and has had very little control over building ( look up Conconully Wa.). They are now getting control of the issues ( Thank you Zac) my concern is the area is growing and becoming a vacation spot. How much can a 6" pipe handle?
Old 03-03-2010, 08:44 AM   #5
Doing it myself
Alan's Avatar
6" pipe will take a whole-heckuva-lot more than 3 single wides.
Journeyman Plumber
Old 03-03-2010, 09:23 AM   #6
Simple math indicates the cross sectional area of a 6" pipe is 4 times larger than a 3" pipe.
HooKooDooKu is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 08:30 AM
