Underground Hot Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2008, 01:04 PM   #16
Foamglass
Whenever you are insulating a pipe which is going to be burried, you need to use a type of insulation called FoamGlass. The insulation also needs to be sealed with a moisture barrier called Pittwrap. You would need to contact an industrial insulator to get this material. All other insulation would be vulnerable to moisture.
BobVilla is offline   Reply With Quote
Water line for new refrigerator? pa555 Plumbing 5 06-08-2012 06:06 PM
Underground Electrical Line and water line. Randell Tarin Electrical 11 09-18-2011 08:19 AM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 07:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
