Underground Gutter Drain Question...foam? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2012, 09:14 PM   #1
Underground gutter drain question...foam?
All my downspouts connect to underground pipes that flow to a large pond behind my house. I have one spout that I noticed the ground was worn away around and during rain I saw water spewing from where the spout meets the black flex pipe going underground.
I took it apart the next day and pulled out a few handfuls of leaves and put the hose in there as soon as I turned it on water stared backing up right away. Used a little snake and it kept bringing up chunks of foam. I managed to stick my arm down there up to my shoulder and with a screwdriver in my hand sure enough a wall of foam just out of reach.
Is this normal? I thought maybe it's there to let water through but keep it easy to clean? But it does not seem to be letting water flow.
So what's the story with this "blockage"?
Thanks!
detyianni is offline   Reply With Quote
Old 06-03-2012, 09:54 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,... It shouldn't be there.....
Drainage tiles should be free flowing, the whole way...
Old 06-03-2012, 10:04 PM   #3
Thanks for the reply. So should I just plow through it with a real snake? I just had a little hand one for sink drains on hand.
I have only been in the house a couple years and never had underground drains
Old 06-08-2012, 08:29 PM   #4
Rewards Points: 87
Here is what I would do. If you can reach it then it is not too far so I would dig up the groung to where the obstruction is. Cut the black pipe and remove the foam and them repair the drain pipe.
TGMcCallie is offline   Reply With Quote
Old 06-09-2012, 08:30 AM   #5
Bill Kearney
Rewards Points: 1,174
Where'd that foam come from? What kind is it? I'd want to know where that came from first.
wkearney99 is offline   Reply With Quote
Retaining Wall / French Drain Question bsmith95610 Landscaping & Lawn Care 8 05-18-2012 09:48 AM
Replacing putty in shower drain, question about drain construction scottyv81 Plumbing 4 03-28-2011 07:43 PM
Question regarding floor drain and sump pump combo vetting Plumbing 9 07-29-2010 01:10 PM
Dishwasher Drain Question kypper Plumbing 2 01-15-2007 11:39 PM
Shower drain question, diy'r Plumbing 6 11-14-2006 02:30 PM
