Underground Gas Pipe To Outdoor Kitchen - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2009, 08:11 AM   #1
Underground gas pipe to outdoor kitchen
Which is best and easiest for an experienced engineer/do-it-yourselfer to use? My town allows either coated black pipe or PEX, but says that their inspectors haven't seen coated black pipe used in a long time. It is available at Lowe's, but the tape required for taping fittings is not. Overall, it appears that the coated black pipe is less expensive, primarily due to the cost of the PEX gas fittings and risers (of which I'll need 4 risers). A 1" riser, for example is $70, and a 1" tee is $30. PEX for gas is only available at wholesalers, sold under brands such as Gastite.
Which product would you recommend that I use? Coated black pipe or PEX?
gotgasss is offline   Reply With Quote
Old 06-03-2009, 08:30 AM   #2
RippySkippy's Avatar
PEX buried with a tracer.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-04-2009, 08:25 AM   #3
Registered User
Termite's Avatar
Gastite's PE tubing for gas burial is the way to go in my opinion. You will need a plumber to do it for you though...It isn't a DIYer system and like you said, responsible wholesalers do not retail it unless the buyer has received the certification to install it.
Just to be clear, PE tubing shouldn't be confused with Gastite's CSST tubing, which is not for a direct burial application.
Old 06-04-2009, 10:49 AM   #4
Perhaps the rules have changed over the years but it used to be that steel pipe for gas, underground, needed to be welded. We used X-trucoat pipe and wrapped the welds with their brand of tape at joints. Anode bags were often required due to acidic soil conditions. Never seen a threaded joint in underground gas lines.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 08:32 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
