Old 01-22-2010, 02:08 PM   #1
Underground copper pipe protection
I am going to install a 1" type L copper service line from water meter to home. Is there anything that can be used to protect the pipe from the soil etc?
Stephen S. is offline   Reply With Quote
Old 01-22-2010, 06:21 PM   #2
Why do you want to go with copper? Why not poly-pipe?
Ishmael is offline   Reply With Quote
Old 01-23-2010, 08:11 AM   #3
If your going to run copper run K copper not L do it once that's it.
And no joints underground. Use long roll.
SULTINI is offline   Reply With Quote
Old 01-23-2010, 10:44 AM   #4
based on the price of copper these days, I too ask, why not poly (plastic)?
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-23-2010, 11:52 AM   #5
The plumber is gonna charge me the same (or close) for PEX pipe vs copper pipe. (I wonder why but I bet copper is more valuable, better underground than PEX?) I was gonna do PEX myself but I found that there are quite a lot of works and involve some heavy duty tools instead of hand tools that I am more comfortable with. Trencher, jackhammer, concrete foundation work, main service meter, etc.
I also have a few other projects that should be done asap. (Just replaced a new skylight yesterday with new flashing and surrounding shingles since the old one was leaking), major bathroom remodel, new flooring, etc ..
The guy told me type K pipe is not necessary and type L is good enough ? How much more are we talking about 100ft type K vs 100 ft type L? Thank you.
Old 01-23-2010, 12:35 PM   #6
Defiantly go with the copper but make sure it's K and it's one continuous line with no joints.
Get price quote from contractor.
Old 01-23-2010, 01:39 PM   #7
Master General ReEngineer
Bondo's Avatar
Ayuh,... Bed it in Sand,.... 1/2' below,+ a foot above the tubing...
Old 01-23-2010, 05:32 PM   #8
You can put armaflex around it if you want it's like black rubber stuff refrigeration tubing is insulated with.
Old 01-23-2010, 08:16 PM   #9
retired elect/hvac/plumb
plummen's Avatar
just bury it in the dirt making sure theres no rocks near by,around here we have to run K copper underground.
plummen is offline   Reply With Quote
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-14-2011 12:48 AM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 06:29 PM
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 07:25 PM
electrolysis on copper pipe amakarevic Plumbing 5 03-24-2008 09:08 PM
Old preasure valve, new copper pipe. fast380 Plumbing 5 01-12-2008 11:36 PM
