Underground Container Vs. Sewer? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2009, 06:39 PM   #1
Rewards Points: 150
Underground Container vs. Sewer?
Hi all,
Has anyone heard of a "new" underground container system that is being used insted of sewers?. A friend of mine mentioned something about an underground container under the house for black water that filters the water and retaines the solid waste. They are supposed to last about 20 years before they need to be replaced. I plan to build a guest house on the backyard and thought this would come in handy instead of running 100 ft of sewer lines from my house.
gante is offline   Reply With Quote
Old 03-18-2009, 06:47 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Ayuh,... It's called a Septic Tank,+ Leech Field.... Google it up...
They don't come Cheap,+ there are usually restrictions on Where they can be used...
Bondo is online now   Reply With Quote
Old 03-18-2009, 07:01 PM   #3
Rewards Points: 150
I saw that coming! . No, it would not be a septic tank. It would be a lot smaller, easy to clean, easy to install and affordable.
Old 03-18-2009, 08:25 PM   #4
Rewards Points: 1,418
I think you are referring to a "composting toilet".
Now there has been for a long time an "old" underground container system which did as you described and the container was porous. It's called a cesspool. It is constructed in the same manner as a dry well except not filled with crushed stone and therefore needs a sturdy lid with clean out hatch.
Cesspools (for black water) are illegal in most communities nowadays.
Yet another undeground container system is a holding tank with pump used in communities where the sewer system is at full capacity. Homes use this system to meet a restriction of being able to use the sewer only during certain hours.
Cesspools were installed a little ways away from the house, not underneath. I could conjecture that at one time long ago they were installed like a latrine, underneath the house as part of the invention of indoor plumbing. The toilet was the one and only hatch. The ultimate behavior was pretty much the same as a composting toilet. Sometimes a second, lower level, hatch was also installed to permit removal of the "compost" for other use such as fertilizer.
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-22-2008 12:48 AM
sewer and shower/sink drainage join underground? toolmanwannabe Plumbing 2 01-21-2008 01:19 AM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 05:19 PM
