Underground Connection To Cast - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2011, 10:30 AM   #1
Underground connection to Cast
Adding an addition to my home. In order to connect to the septic tank, I'm going to need to go through the (new) basement wall and connect to the 4 inch cast iron line going to the septic tank ouside (underground).
I've excavated down to the pipe (see picture) and need to know the best way to connect in.
My plan (not sure if its a good one)
cut out section of pipe long enough to fit plastic wye with short extensions glued into it. Use ferkos at both ends of wye to make connection between iron (see drawing attached)
teststrips is offline   Reply With Quote
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
