Undergound Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2007, 08:47 PM   #1
Rze
Average Joe
Rewards Points: 79
Undergound plumbing
Looking to run water to my sister in laws shed. Heard something about a Flex Tubing ot flex piping that I can run out to a spigot at the shed. Does any one know:
1) What this stuff is called? (Something like PEX)
2) whats the best way to connect it to copper?
I know it will have to be blown out in the winter months.
Thanks!
Dave
Rze is offline   Reply With Quote
Old 10-23-2007, 06:37 AM   #2
RippySkippy's Avatar
I would use the black plastic water pipe available an any home improvement place. Assuming you have a place to connect to, you should be able to locate a brass sweat fitting with barbs on the plastic end. If you have a threaded connection there should be either male or female with barb. (I couldn't find the fittings I'd use, these pictures just help show the style of threaded fitting.)
I like the red brass fittings, with 2 stainless clamps per connection. To aid in getting the pipe over the fitting, heat the pipe gently, and it'll slip right on. Too much heat will trash the pipe.
RippySkippy is offline   Reply With Quote
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 12:41 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
Shower Plumbing Ron Plumbing 1 08-15-2007 11:38 AM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
New home plumbing cost wdsfr1968 Plumbing 7 07-28-2006 09:41 AM
