Underfloor Heating Problems - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2011, 12:25 PM   #1
Underfloor heating problems
A question for a friend of mine.
He has UFH upstairs and downstairs (downstairs are where the bedrooms are).
Upstairs is fine, feed is 40 degree, return is 31 degrees. Good heat and all thermostats hit 19 degrees.
Downstairs has 5 zones. All on thermostats. 4 of the zones are hitting 19 degrees no problem at all but 1 room won't go above 16 degrees for some strange reason.
All bar 1 are timber.
The feed is 40 degrees and the return is 40 degrees (is this not odd) .
I took the actuator off the cold room and it went to 17 degrees for about 10 mins then back down to 15 degrees.
when I did this though another room went to 21, even though the thermostat is set to 19.
Any pointers?
aidangill is offline   Reply With Quote
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 03:53 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
