Old 05-21-2011, 05:39 PM   #1
Under-slab supply line?
I am running supply lines of pex from a utility room to the kitchen. It is nearly 50' If I follow the path of the drain line, the trench is open still for inspection on Mon. I am debating weather I should insulate the hot water line or not, and if so, what is the proper way to do it? It is under a heated slab in southern Mi, so the soil should be around 60 degrees.
My plan was to insulate with standard pipe insulation, and then stuff that in electrical conduit. I would run that in a straight shot from utility room to kitchen, maybe about 30-35 feet when not following the drain. I can not do that till after I fill in the drain trench cause they cross and will cause many cave ins I fear. thanks
rockyrunner99 is offline   Reply With Quote
Old 05-21-2011, 05:51 PM   #2
call me E
TheEplumber's Avatar
Sounds OK but I personally wouldn't use the conduit. I don't think its necessary.
Old 05-21-2011, 10:22 PM   #3
well my reasoning for the conduit was the pipe insulation will get compacted from the sand and cement and lose its insulating value. Yes it may be overkill, but there is no doing it later.
Another issue I have is using 1/2" pex. It is supposed to be 1/2" ID but the ID is smaller then 1/2" copper. I realize it is just a sink, but will 1/2 inch be enough, I want good flow so I can fill a pot in less then a few hours! I might see if the flow restrictor can get misplaced somehow
Old 05-22-2011, 12:46 AM   #4
call me E
Only on rare occasional will 1/2" not be large enough for a sink. Depending on the water pressure, 2 or 3 fixtures are usually put on 1/2"
Old 05-22-2011, 12:58 AM   #5
Persona Non Grata
VIPlumber's Avatar
...but will 1/2 inch be enough, I want good flow so I can fill a pot in less then a few hours!
It'll be fine. Remember that the shutoff and line to faucet is only 3/8" so your restriction is actually through there.
VIPlumber is offline   Reply With Quote
Main Water Supply line Issue joe.shrigley Plumbing 7 07-16-2010 06:24 AM
sealing around copper water supply line dazedanconfused Building & Construction 4 09-22-2009 05:55 AM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 10:54 PM
Moving a gas line when house is on a slab Socrmom3 Appliances 4 01-24-2008 12:32 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
