Old 09-10-2012, 02:17 PM   #1
Trucon01's Avatar
Under slab plumbing help
Hi Guys,
I'm currently digging up my basement slab to lay a french drain as well as re-plumb a toilet and shower. (See picture)
What all do I need to be concerned about? The current pipes are cast iron and will be replaced with PVC. I got a quote for 600 bucks to run a line and attach it to the main.
Is this something I should do myself? I'm assuming I use a 3-4 inch dia PVC pipe with a closet flange and a shower drain?
Thanks for reading.
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 09-11-2012, 12:07 AM   #2
Persona Non Grata
VIPlumber's Avatar
Depends on how far the $600 gets you. All the way to the street? Let them do it. Just what we see? DIY it.
You'd use a 3" line as a replacement.
VIPlumber is offline   Reply With Quote
Relocating plumbing - concrete slab foundation vsheetz Building & Construction 17 04-23-2011 06:22 AM
moisture under slab, roughed-in plumbing bergerdude Building & Construction 4 03-25-2011 09:29 PM
Plumbing through a slab phxhome Plumbing 7 09-01-2010 12:50 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
