-   -   Under slab plumbing help (http://www.diychatroom.com/f7/under-slab-plumbing-help-156413/)
Trucon01 09-10-2012 02:17 PM
1 Attachment(s)
Hi Guys,
I'm currently digging up my basement slab to lay a french drain as well as re-plumb a toilet and shower. (See picture)
What all do I need to be concerned about? The current pipes are cast iron and will be replaced with PVC. I got a quote for 600 bucks to run a line and attach it to the main.
Is this something I should do myself? I'm assuming I use a 3-4 inch dia PVC pipe with a closet flange and a shower drain?
Thanks for reading.
VIPlumber 09-11-2012 12:07 AM
Depends on how far the $600 gets you. All the way to the street? Let them do it. Just what we see? DIY it.
You'd use a 3" line as a replacement.
