Old 11-12-2009, 11:41 PM   #1
Under slab plumbing
Hi, i am installing new pvc dwv plumbing under the basement floor. (old concrete removed and new floor to be poured) there is a 4 inch stack that comes straight down the wall and then makes a short 45 deg to avoid the footer before becoming horizontal under the slab. The location for a toilet is just about 2 feet from the stack and almost directly over the horizontal 4 inch pipe. I have room to install a y and 45 deg combo to serve as the toilet riser. There would be no specific vent for the toilet other than the venting provided by the nearby stack. Is this arrangement acceptable or do i need to provide for a seperate vent for the toilet somehow? Thanks
SS396 is offline   Reply With Quote
Old 11-13-2009, 06:27 AM   #2
Remodeling Contractor
Under slab plumbing
if your local codes permit wet venting you will be fine.
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Starting with a straight line while constructing a wall, hanging wallpaper or displaying artwork can be the key to whether the project succeeds. Begin the job right and use a plumbline or plumb bob to achieve a straight, vertical line. Read More »
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
Bathroom Design Ideas
Bathroom Design Ideas by Expert Village
When I met with the homeowner he told me where he wanted to build his new bathroom and what he wanted to have in it and where he wanted to have it. Originally he wanted the toilet where I am standing and I told him I thought it would be better in the... Read More »
Shower Pan and concrete slab plumbing LTempleton Kitchen & Bath Remodeling 2 08-08-2009 01:47 PM
Plumbing Under Slab (New Construction) zzyzx Building & Construction 9 11-22-2008 01:41 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 08:37 PM
Ant's through slab plumbing aace Pest Control 4 02-13-2008 04:48 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
