Under Sink Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2009, 07:49 AM   #1
Under Sink Help
I noticed yesterday that my sink drain was not connected to the tailpipe. After many tries, I was able to screw it back together (see picture). That no longer seems to be an issue. However, it's not on very tight; does the tail pipe need to be replaced with a plastic slipnut?
Also, see the other attached pic. Water is also leaking from the drain itself. You can see a drop. Does this mean I need a new drain?
This work was done by plumbers who screwed up many things in my house. Let me know if it looks like bad work.
thank you
picsaro is offline   Reply With Quote
Old 02-01-2009, 09:52 AM   #2
hey man,
i had a similar problem when i first installed my new sink.
here's what i recommend (though i don't claim to be a plumber):
1) buy a pipe wrench
2) take everything apart. anything with threads i would wrap with teflon tape 3-4 revolutions, AND slather with pipe dope.
3) put everything back to together and crank down on that drain tailpiece HARD.
i see no reason why you should need a plastic slip nut, just tape and dope and tighten it hard. you won't get the necessary leverage with a vice grip or whatever.
shouldn't be anything there that's actually broken. just loose and leaking. you may need a new rubber washer or two on the slip nuts.
take it all apart and have a close inspection.
pipe dope is the king!
wombosi is offline   Reply With Quote
Old 02-01-2009, 12:07 PM   #3
thanks. i was able to tighten everything and that worked.
Old 02-01-2009, 12:27 PM   #4
awesome.
Old 02-05-2009, 07:24 PM   #5
I spoke too soon. It still keeps coming loose. I tried teflon tape, pipe compound, and used a wrench. It makes a couple of turns, then comes loose. I'm assuming either the nut or the strainer is stripped. Any other ideas? If something is stripped, what do i do next? Totally disconnct the tail pipe so I can replace the nut?
Old 02-05-2009, 08:11 PM   #6
sorry to hear of the continued troubles. i know exactly how annoying this is.
i'd take it all apart. inspect the threads of each. very easy to go to hardware store and buy a new $2 nut/washer set. replacing the entire drain pipe would be very easy too, and cheap.
not sure the nuts with the rubber washers require tape or pipe dope, as i think the washer itself is meant to make the seal.
everywhere else though, should have a good 4 tight wraps with tape, and generously slathered in dope, then tightened to holy hell with a pipe wrench.
keep chipping away dude. sounds like something is stripped. take it apart and a trip to the hardware store should solve it.
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 06:42 PM
