Unable To Stop Leaky Kitchen Faucet W/ New Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2011, 08:45 AM   #1
Rewards Points: 248
unable to stop leaky kitchen faucet w/ new valve
EDIT: problem solved with new plastic bearings that fit inside the faucet hub.
We have a Kohler single-lever kitchen faucet that won't stop leaking when the faucet is rotated towards the right side of the sink.
Not sure of the model # but it resembles the Forte. When it started to leak I took it apart, removed the valve, got the valve P/N, and requested a replacement from Kohler.
The valve has an integrated red gasket, roughly clover-shaped, that sits in a groove in its base. There are no plastic bearings or o-rings. The valve also has two plastic prongs on its base that mate with holes in the faucet.
I lubed the gasket with Dow 111 silicone, reseated the valve taking care to mate the prongs with the holes in the faucet base, tightened down the lock nut hand-tight, turned on the valve -- some water gurgles up out of the top of the valve-- so I tighten the lock nut another quarter-turn with a wrench, and the water stops coming out the valve.
However, when I move the faucet towards the right, water wells up and trickles out onto the counter top. Tightening the locknut an additional quarter-turn, half-turn, three-quarter-turn, so it's very tight, does not stop that trickle. Loosening the locknut until water gurgles out the top of the valve, and then barely tightening it again until that gurgling stops, doesn't fix the leak that happens when the faucet is moved.
Any ideas why rotating the faucet should have any effect on the valve seal?
diy888 is offline   Reply With Quote
Leaky furnace valve billinak HVAC 9 11-01-2009 07:11 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
Leaky Bathroom Faucet w No Markings cmcwittig Plumbing 6 12-23-2008 09:55 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Help ! May have to replace older model Streamway mobile home tub faucet valve body !! Musicloverz Plumbing 2 01-26-2008 07:04 PM
