Unable To Install A Reverse Osmosis System? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-04-2012, 09:49 PM   #1
Unable to install a reverse osmosis system?
We just remodeled our kitchen and we decided to go with a large single bowl sink instead of a double sink. Now we are being told there is no way to install a reverse osmosis system (short of drilling a whole in the wall and draining the system to the front yard) because you can not put the drain down line of the garbage disposal. Is there any way to put the drain in the same location as the dishwasher or any other solution. Thank you
smitts is offline   Reply With Quote
Old 06-04-2012, 11:43 PM   #2
Sure you can. Just tie the drain in before the P trap, independent of any other drains (d/w, disposal, etc..) See below. Make sure to get a stainless steel saddle clamp as the plastic ones are crap.
VIPlumber is offline   Reply With Quote
Can I install European light switch on NA system? BuckyGunts Electrical 19 05-06-2012 05:20 AM
A strange one - polybutelene piping used in radiant heating system GordCooper Plumbing 4 03-13-2012 10:09 PM
how difficult to install reverse osmosis filter grgryl Plumbing 3 02-07-2009 10:04 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Reverse Osmosis setup billybarty General DIY Discussions 1 05-30-2008 09:15 AM
