Old 10-23-2009, 04:55 PM   #1
Uh oh-wall too close to the toilet drain?
I'm finishing my basement, and realized that I might have built one of my interior walls too close to the toilet drain. I found in a book that it should be 12" on center away from the finished wall. Mine is 11.5" from the UNfinished wall.
Do you expert types think this'll be a problem? It would obviously be painful to move the wall back another inch, but it would be a lot easier to do while it still doesn't have any sheetrock on it.
Thanks in advance!
RobbL is offline   Reply With Quote
Old 10-23-2009, 05:52 PM   #2
nap
You talking to me?
nap's Avatar
the distance is required for the installation of the toilet itself. There are units that have a lesser center from the wall measurement but regardless, unless you fall in love with such a toilet, I would correct the drain set now so you will not be limited to what toilets you can use in the future.
Old 10-23-2009, 06:01 PM   #3
We pick these?
Make sure you have 15" or more either side of center as well. I have a closet drain that I'm about to have to do something about that was roughed in 12"x12" back in 1965. People living here since then have had to sit crooked on the seat when using it for lack of side-clearance.
NailedIt is offline   Reply With Quote
Old 10-23-2009, 06:43 PM   #4
GC/Master Plumber/Mech
While most toilets require 12" from finished wall there are toilets that are 10" from finished wall
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-23-2009, 06:46 PM   #5
A "Handy Husband"
rjniles's Avatar
While toilets require a nominal 12 inches from the finished wall, I have found most toilet will mount fine with 11+ inches.
rjniles is offline   Reply With Quote
Old 10-23-2009, 07:35 PM   #6
Great thanks a lot, everyone. It sounds like my best course of action would be to head to the home-improvement store and make sure that there is a toilet there that we like which will mount with the slightly shortened distance to the back wall.
I have 16" on center to the side, so I'm okay there. That's a good thing because that's an outside wall, so there wouldn't be much I could do there without busting up the concrete.
Thanks again!
Old 10-23-2009, 09:15 PM   #7
Super Moderator
You would do well to move the wall. The expense of not doing that will make you sorry.-MIKE-
oh'mike is online now   Reply With Quote
Old 10-24-2009, 11:29 AM   #8
If you go to a 10" rough toilet, you may need blocking between the tank and wall to prevent it being broken if someone leans back too hard. You would have an 1-1/2" space between the tank and wall. Most toilets are "forgiving" for 1/2" measurement, even if you need to move the tank bolts towards the front of the holes and a smidge on the flange bolts. 10" rough toilets are not always available without ordering them at Home Centers.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-24-2009, 01:04 PM   #9
A "Handy Husband"
rjniles's Avatar
And 10" rough in toilets are special order and quite a bit more expensive than 12".
Old 10-24-2009, 04:32 PM   #10
Super Moderator
Get your sawsall and a flat bar. Cut the wall section loose and move it!
You could have the fix done in less time that it took to type out your question.--MIKE--
Wall mount toilet warnerww Plumbing 3 07-04-2011 09:01 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
toilet drain line rbaggett Plumbing 2 11-28-2008 11:54 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
