UGH. Plumber Gone Crazy - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2011, 11:39 AM   #1
UGH. Plumber gone crazy
Had a plumber out to replace a stack. In doing so, he chopped the water supply lines and suggested I run a new gas line in track pipe. The water supplies were all rerun in pex. The home is a 700 sf home. What would be a fair price, parts and labor for new pex and trac pipe, individually. Please keep in mind, he was already on site for the stack. I think I'm getting you know whatted... I realize this varies a lot from region to region... thanks
brokenhammer is offline   Reply With Quote
Old 08-22-2011, 02:53 PM   #2
Experienced
Jackofall1's Avatar
I am not sure I follow your post, you say your plumber chopped the supply line, if that is the case the he should replace it at no cost, as for getting pricing here for any work, it will not be accurate.
We are not there, we can't see what you are looking at, we don't know about interferences, I think that if you want to get comparison pricing then you should bring in another reputable contractor.
Mark
Old 08-22-2011, 04:09 PM   #3
So he cut the supply line which is pex? That's a pretty simple fix, I'm not quite sure what's going on here.
Hatsee is offline   Reply With Quote
Old 08-22-2011, 08:07 PM   #4
plumbing,softener,well
totally agree if one of my plumbers cut a line we would fix it at no cost. i would not pay for his mistake. and yes pex is a very easy fix.
plumberboy69 is offline   Reply With Quote
And The Leak Goes On!....Two Visits From the Plumber Later spyboy Plumbing 11 04-16-2011 09:12 PM
Dishonest Plumber Left Major [Expensive] Issues ConsumerTalk Plumbing 4 03-27-2011 01:23 PM
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
HELP! I'm NOT a plumber. And I don't play one on T.V.! kswoot Plumbing 20 10-02-2008 01:14 PM
