U Shaped Copper Configuration - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2011, 06:40 AM   #1
U shaped copper configuration
First time posting - Doing a toilet replacment and was considering replacing the old straight chrome water line that comes up through the floor that then connects with a flex line to the toilet. I traced back to the copper in the basement and saw the shut off valve, but also a U shaped copper configuration. Does this serve a purpose? I was considering re-piping that area but was just going to use a straight 90 from the line to head up through the floor to the bathroom. Picture attached if I did this right.
cruyf is offline   Reply With Quote
Old 04-25-2011, 07:18 AM   #2
Hard to tell what was in the mind of the original installer, but I know of no reason for that configuration. Make sure you clean off all that paint, and replace the shutoff with a ball type shutoff. Since this is for the toilet, there actually should be a shutoff at the toilet, again, 1/4 turn ball valve.
Old 04-25-2011, 07:58 AM   #3
Plumb or Die!
If that's black iron threaded pipe and a 90 there, get rid of it, too.
plumber666 is offline   Reply With Quote
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Copper or PEX (and which PEX connectors) SFX Group Plumbing 3 11-03-2010 09:06 AM
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 10:23 AM
copper flashing, galvanized nails... sharp Roofing/Siding 4 04-02-2010 07:43 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
