Type Of Pipe For Main Stack To Septic Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2009, 09:12 PM   #1
Type of pipe for main stack to septic tank
Hi everyone,
We are replacing the pipe that leads from our main stack to our septic tank.
It's an old house, and the main stack is currently cast iron, and the pipe that connects the main stack to the septic tank is leaking and we've dug up the ground and are ready to replace the pipe.
I've heard that the white PVC is for pressure and the black ABS is for drainage and venting.
I just want to clarify that the black ABS pipe is the proper type of pipe to use that will go from the main stack to our septic tank.
Thanks for any help anyone can give me.
GD73 is offline   Reply With Quote
Old 08-28-2009, 09:25 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
You can use either ABS or Schedule 40 PVC
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-28-2009, 10:17 PM   #3
Ok, thanks for the reply!
Install manholes (access) hole in concrete septic tank cover rkpatt General DIY Discussions 2 02-23-2009 06:37 PM
Copper pipe type for residential water distribution BigJimmy Plumbing 7 12-31-2007 08:39 AM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 11:33 AM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 09:08 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
