Type L Or M Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2010, 01:14 PM   #1
Rewards Points: 640
Type L or M copper
I need to move some copper 3/4" lines in my house, I think the pipe that is there now is type L, its printed with green ink but most of it smeared or rubbed off to the point I can't read anything on it...
I think I am supose to use type L for this type of instulation? It's just interior potable water... I'm moving a water heater and need to run a line 10 ft... am I picking the right type of copper?
BlueBSH is offline   Reply With Quote
Old 11-19-2010, 01:54 PM   #2
Rewards Points: 1,778
try google; I did and got this site with a lot of discussion of use by application:
http://www.businesshistorybooks.com/...-694538-2.html
bob22 is online now   Reply With Quote
Old 11-19-2010, 01:59 PM   #3
Rewards Points: 640
that's what I did last night and all I ended up was even more confused... with people saying stuff like L is for underground only, use M then another place use L for potable M is for sprinklers..... everyone contradicts themselves... then one place says M is for under 100 psi but then I found a place sayign its for 700 psi and below
Old 11-19-2010, 05:25 PM   #4
The difference is thickness of the wall of the pipe. You should check local codes to make sure there is no special requirement in your area. Subject to the code, if your water is non-corrosive you can get by with M--the thinest wall. If your water tends to be a bit corrosive then L or K--the thickest wall is recommended. Alternatively you might consider using CPVC which is not affected by corrosive water and is approved by most, if not all codes and can be used for both hot and cold domestic water lines.
Bob999 is offline   Reply With Quote
Old 11-19-2010, 05:26 PM   #5
BLue,
I would bite bullet $wise and use the thicker walled. No harm and peace of mind.
Old 11-19-2010, 05:30 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 924
4 grades of copper pipe- listed thickest pipe wall to the thinest.
K - green lettering, usually used for underslab
L - blue lettering. "commercial grade" most commonly speced by enginneers
M - Red lettering. "residentual grade". not used underground
DWV - Yellow lettering. Not approved for presure piping. Waste and vent only
K,L,and M are all OK for above ground domestic water inside a home.
The OD's are all the same
Old 11-19-2010, 08:32 PM   #7
k and l would be fine. m is used primarily for heating. since it is thin walled it radiates the heat as water travels through it. by most codes that i know of you cannot use m for domestic water useage and inspectors would frown upon it.
wellcraft is offline   Reply With Quote
Old 11-19-2010, 08:35 PM   #8
Plumber
Rewards Points: 924
Used daily in my area
Old 11-20-2010, 02:33 AM   #9
I find it more difficult to solder M pipe because of how thin it is, but then again I was trained using L pipe and I've primarily done commercial construction. I find though that I prefer commercial standards over residential since it is usually rated for heavier use, which means it will last longer. I don't care to spend the extra money to have peace of mind knowing that I wont have premature failure.
Of personal experience I have found that mixing the two grades of pipe and fittings will cause problems. Maybe I had a bad batch of fittings, but when I used L fittings with M pipe there was too big of a gap and so I'd use like 2" of solder on 1/2" pipe, which made me angry. I went and bought some M fittings and that problem went away.
immeraufdemhund is offline   Reply With Quote
Old 11-21-2010, 06:45 AM   #10
Rewards Points: 1,216
I have always been partial to "L" it is right in the middle and "M" seems just a bit flimsy for me . To each their own.
COLDIRON is offline   Reply With Quote
Old 11-22-2010, 07:40 AM   #11
Rewards Points: 640
well in the couple fundred feet of copper pipe I finally found a piece I can read and in green print it says "3/4 IN COPPER TYPE L" weird that it's in green print, but oh well... I'll stick with the middle thickness that I have and get L copper
are fittings like T's and curves rated on this same scale or are they universal?
Old 11-22-2010, 08:52 AM   #12
The fittings are "universal" in sizing because the outside diameter of M, L, and K pipe are all the same.
Old 11-22-2010, 08:54 AM   #13
Rewards Points: 640
well I guess I ment universal as in the specifications of the copper type like underground, pressure, etc
How to Rewire aluminum to copper wall outlet. deepseathomas Electrical 1 10-20-2010 02:11 PM
copper flashing, galvanized nails... sharp Roofing/Siding 4 04-02-2010 06:43 PM
Flexible Copper or Rigid Copper? Piedmont Plumbing 1 06-10-2008 01:40 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
