Type Of Hot Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2010, 09:28 AM   #1
type of hot water heater?
Need new hot water heater. Replacing all the plumbing in the house. Any suggestions on a hot water heater? Gonna be 6 people showering daily. Curious about the tankless hot water heaters. Any comments on those? Also, if i go with a standard hot water heater unsure of what size to get.
w36cowgirl is offline   Reply With Quote
Old 03-24-2010, 09:40 AM   #2
While tankless heaters are all the rage, there can still be many problems. This is one case where "not all units are created equal" is true. Don't buy a cheap unit (even though most are expensive anyways). Make sure you know what the output is and if it serves your purposes. Most units require professional installation to preserve the warranty. Although many Plumbers will install them, not all will do maintenance or repairs since they are difficult to work on. Sounds like you need at least a 50 gallon, quick recovery, heater.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-24-2010, 09:48 AM   #3
thank you so much. i think i will just stick with a standard hot water heater. sounds like tankless may be expensive to purchase and even more expensive to repair. thanks
Old 03-24-2010, 07:47 PM   #4
water flows downhill
oarfish's Avatar
I got a tankless Rheem 180000 BTU on Ebay for $599 shipping included.
The vent kit was $189 shipped + more extension venting from Rheem $ 70.
If you do your own installation it can be cost effective.
oarfish is offline   Reply With Quote
Tankless Water Heater welshie Plumbing 12 03-03-2010 12:46 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 03:32 AM
"sticky" gas water heater thermostat homer12 Appliances 8 01-25-2008 04:36 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
