Tying In ABS Drain To Galvanized Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2012, 10:25 AM   #1
Rewards Points: 35
Tying in ABS drain to galvanized pipe
I have some suspect plumbing I am forced to make do with. Someone has tied an ABS pipe into a galvanized pipe stub and it has a small leak from the adapter fitting. See picture below. What kind of fitting is this? Is there some sort of Fernco that would be better suited for this situation?
tunabreath is offline   Reply With Quote
Old 05-10-2012, 07:06 PM   #2
Rewards Points: 636
yes a sheilded fernco like this
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-10-2012, 07:08 PM   #3
Rewards Points: 13,456
Why in the world is there a drain or vent pipe sitting inside the room?
Old 05-10-2012, 07:16 PM   #4
Rewards Points: 636
yea i was wondering the same thing 3 options
1 carpeted bathroom and a pedestal sink is going there
2 wash machine stand pipe
3 the new never miss urinal pipe
Old 05-11-2012, 05:17 AM   #5
Rewards Points: 35
Originally Posted by jaydevries View Post
Will that work? The ABS pipe looks to be 1.5", and the galvanized 1.25"?
This is what happens when you are young and stupid and buy a house without a home inspection.
That is the kitchen sink drain, and the carpet you are looking at is on a false floor in the basement. The basement was finished MANY years ago, and it appears that the kitchen sink is now draining into a floor drain. It is not feasible for me (mentally and financially) to rip out this false floor now because:
1) the main sewage stack is on the other side of the house (30 feet distance diagonally?) and there is a drop ceiling already installed tight to the floor joists
2) I'm at my wit's end with this house
I already installed a mechanical vent on the kitchen sink, but drainage isn't much better. When installing the mechanical vent, I realized that the whole ABS pipe could rotate independent of the galvanized pipe, which must have started the VERY SMALL leak.
Old 05-11-2012, 08:59 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you sure it's galvanized? I haven't seen much 1-1/4" galvanized. It doesn't look like it from the picture, but could it be copper? Sometimes photos are deceiving.
There should be 1-1/4" fernco couplings as well.
Journeyman Plumber
Old 05-11-2012, 10:22 AM   #7
Rewards Points: 35
Camera didn't capture the color too well, sort of looks copper in the picture, but it is silver. I will put a magnet to it to be sure? Either way, what type of adapter is on it now in the picture? It almost looks like some sort of compression fitting. I will look for a Fernco of the proper size.
Old 05-11-2012, 11:15 AM   #8
Rewards Points: 1,294
You have what is called a Trap Adapter http://www.lowes.com/pd_23296-1814-P...%7C1&facetInfo=
Definitely the wrong application for that part. The water is flowing thru it in the wrong direction for what it is intended. Not sure what pipe diameters you have as pipe is measured as Inside Diameter but, there are fernco couplers available for almost any application. One word of caution though...you are draining a larger pipe into a smaller pipe which tends to cause clogging problems at the transition.
danpik is offline   Reply With Quote
Old 05-11-2012, 12:42 PM   #9
Rewards Points: 35
Now I am worried. I bet I will find caulking or some sort of sealant on the inside if that is what is there.
Thanks.
Old 05-11-2012, 01:13 PM   #10
There should be a compression gasket in there if you take it apart. it is designed to hold the tailpiece of a trap assembly in place and create a seal when used properly
Old 05-11-2012, 04:26 PM   #11
Rewards Points: 636
they make a sheilded fernco for plastic to copper 1 1/2 on plastic side and other side has a thicker rubber wall for the copper side. home depot carries them here but not lowes just look at thickness of rubber on each side to make sure they are different. it might look silver due to solder
Old 05-11-2012, 08:06 PM   #12
Household Handyman
Rewards Points: 1,408
@ Alan--You should have worked where I used to work. All of our guardrails around machinery was made with 1 1/4" galvanized piping and "keylock" fixtures. And NO--they did not allow painting of the guard rails for some odd reason.
Old 05-11-2012, 08:28 PM   #13
Rewards Points: 582
looks like crome 1 1/2 tubluar to be able to connect to 1 1/2 abs desanko??????
Old 05-12-2012, 09:44 AM   #14
Doing it myself
Alan's Avatar
Well I have seen 1 1/4 galvanized for that kind of stuff. Just not plumbing.
Journeyman Plumber
Replacing Old Rusted Galvanized Pipe Under Foundation JLW2099 Plumbing 7 04-02-2012 02:15 AM
drain pipe slips off tail pipe tomad51 Plumbing 4 07-04-2011 02:06 PM
Best way to cut galvanized drain pipe? Arlo Plumbing 3 08-26-2010 04:44 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
