Tying 1 Toilet To Existing Toilet Drainline - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2012, 05:18 PM   #1
Tying 1 toilet to existing toilet drainline
Here's my deal...
I have an older home, 1950, raised off the ground by 2 feet. I have a toilet line that goes straight down from toilet to sewer. I am installing a 2nd toilet 5 feet away and want to drain this one into the existing line. If I add a Yee Tee and a vent stack (none present) will I get flow and not suck the water out of the existing one??
Thanks in advance
Insuralife is offline   Reply With Quote
Old 05-05-2012, 05:49 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
if cut into the vertical stack you should be ok
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Insuralife (05-05-2012), jaydevries (05-05-2012)
Old 05-05-2012, 08:57 PM   #3
Thanks!
Would the vent be best placed closest to the distant toilet or should I place a vent where the distant toilet ties into the existing toilet line?
Plumbing sure is an interesting creature.
Air sure helps poop move! Shame it doesn't work as well in Washington!!
downstairs toilet now leakiing after replacing upstairs toilet davesj Plumbing 3 12-03-2011 05:03 PM
Help with stink coming from Toilet area. Integraoligist General DIY Discussions 9 11-16-2011 05:16 PM
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 10:02 AM
Where to Move this Toilet? estburke Plumbing 8 10-10-2010 11:52 PM
Tying into existing roof Warren Roofing/Siding 2 05-06-2007 07:42 AM
