Two Wells To One House? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2010, 06:05 PM   #1
Two wells to one house?
I have two drilled wells with submersible pumps. One is plumbed to a tank and valve in an out building and the other to my residence. Each has rather slow recovery but If I use both in the summer I never run out. Has anyone hooked two to one house? To complicate matters worse the house is on a slab. I could easily connect to the current house supply line underground outside.
Drogge is offline   Reply With Quote
Old 02-12-2010, 06:29 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it a storage tank or a pressure tank?
Journeyman Plumber
Old 02-12-2010, 06:41 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
when you say slow recovery, do you mean the water level within the well drops as it is pumped and is slow to refill or simply that either pump does not pump enough water to keep up with what you are using?
Old 02-12-2010, 06:49 PM   #4
Typical recovery for this area is about 3/4 gallon / minute. They are slow to fill 10"dia. casings about 60' deep.
Old 02-13-2010, 12:18 PM   #5
Doing it myself
Alan's Avatar
rwq.....
Journeyman Plumber
Old 02-13-2010, 09:21 PM   #6
nap
You talking to me?
nap's Avatar
if you want to run the pumps independently, there would be no problems I can think of. Just put in an alternator that runs each pump every other time. That would allow the other well more time to recover.
If you use more than the wells supply, it doesn't matter how many pumps you run. You will simply run out of water.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
