Two Waste Water Nibs - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-29-2010, 11:25 AM   #1
two waste water nibs
we recently purchased a new home and have a question regarding the kitchen sink plumbing.
we have a double sink. the dishwasher drains into a wastewater nib on one drain line. the other drain line has a waste water nib that has a 1/2 inch clear hose attached to it that runs through a drill hole in the bottom of the cabinet. this clear hose is full of water but we have no idea what this waste water is.
any thoughts would be appreciated.
thanks,
garden659 is offline   Reply With Quote
Old 09-29-2010, 12:57 PM   #2
Chicago, IL
Michael Thomas's Avatar
Most likely suspect is the condensate drain from a HE furnace and/or AC expansion coil.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
the_man (09-29-2010)
Old 10-05-2010, 01:56 PM   #3
michael,
thanks so much for the suggestion. i was able to track the condensate drain from the AC/furnace back under the ceiling insulation to the sink. mystery is solved.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water running down waste pipe rav927 Plumbing 5 07-04-2009 09:24 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
