Two Tub Spout Pipe Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2013, 03:00 AM   #1
Rewards Points: 175
Two tub spout pipe questions
I recently remodeled a bathroom. Is it OK to caulk around the tub spout copper pipe where is exits the wall? More specifically, caulk the hole in the drywall that the pipe exits out of? I'm thinking that this will prevent any water from getting back behind the wall ...
Also, despite my efforts, the copper pipe is not square to the wall. I've tried bending it, to no avail. I used a threaded elbow for the tub spout, and screwed it to board. Would severing the screws make it any easier/better? I could replace the pipe coming out of the wall (since it's a threaded connection), but I'm not sure how that'd help me...
Thanks for your help,
Richard
RichardZ is offline   Reply With Quote
Old 07-28-2013, 03:56 AM   #2
Rewards Points: 352
seal the hole with plumbers putty
plumberinlaw is offline   Reply With Quote
Vent pipe, 2 questions moneymgmt Plumbing 14 12-06-2012 10:37 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 08:00 AM
tub spout kit install questions wengang1 Plumbing 3 11-24-2011 03:09 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
