Two Toilet Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2007, 02:14 PM   #1
Rewards Points: 1,062
two toilet questions
1. which part of the toilet is broken if the handle must be kept down the whole time through a flushing ?
2. which part of the toilet is broken if it is leaking water through after getting filled (it does not "know" when to stop refilling ) ?
Old 11-26-2007, 02:19 PM   #2
Rewards Points: 150
1) flapper
2) flapper
Although 1) could be just adjusting the flapper chain as well... but if it was working normally then it stopped, then it's just flapper again.
slakker is offline   Reply With Quote
Old 11-27-2007, 10:48 AM   #3
Both questions are due to the flapper. Remove the tank lid and look at the flapper. It may have a broken connector (small ears) where it attaches to the overflow tube or it may have mineral deposits on the seating area under the flapper. Turn off the water supply valve under the toilet. Flush. Now lift the flapper and clean off the seating surface and the bottom of the flapper to remove deposits. Drop the flapper back down and adjust the chain/strap that connects to the flush handle. There should be only enough slack to allow the flapper to seal. Turn the water valve back on and let the tank fill. Flush. The flapper should stay up until most of the water is out of the tank. The tank should then refill and not allow water to leak through to the bowl. If it still leaks through, purchase a new flapper and install it. As a note, take the old one with you and get the same type. Many new types are available with promises that can mess things up more than solve problems. Good luck.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 01:34 AM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 10:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 08:34 AM
