Two Sinks - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2008, 08:41 PM   #1
two sinks
I am installing two sinks were there is only one do i need to put the drain in the wall or can i leave it in the cabinet and do i need separate water lines for each sink
jersey boy is offline   Reply With Quote
Old 01-22-2008, 02:43 PM   #2
I blame ProWallGuy
Rewards Points: 150
Although not common, most model codes will allow you to connect two lavatory sinks with a continuous end-outlet waste, much like used under a kitchen sink.
As long as the service stops are accessable, then you don't need to run piping in the wall seperately for each sink. You can tee off of the one sink.
If you do use a continuous waste, then only one trap would be installed, if you use a wye, then each sink would need to be properly trapped.
Both these sinks will be in the same cabinet?
Double A is offline   Reply With Quote
Old 01-22-2008, 07:57 PM   #3
yes they will be in the same cabinet and thankyou for the info very helpful
Old 01-23-2008, 05:53 AM   #4
yes the codes allow them to be conected. but the distance between the sinks has a max of 30" apart in the UPC
ranman469 is offline   Reply With Quote
Old 01-23-2008, 06:19 AM   #5
Rewards Points: 324
What if they arent in the same cabinet and they are two sinks back to back separated by a wall, but are within 30"? Can they still be tied together only using one trap?
tigerbalm2424 is offline   Reply With Quote
Old 01-23-2008, 06:54 PM   #6
nope. same cabinet
code 3201.6 1 trap may serve up to 3 sinks, laundry tubs or lavs of the same type in the same room
Old 01-23-2008, 07:07 PM   #7
thank you i did not know how bad is it to cut the pipe in the wall and set it up for two traps
How would I fix/re-do my sink's drain <leaking> piping? joeyboy Plumbing 17 12-18-2007 05:23 PM
Two kitchen sinks on one vent? Alsomee Plumbing 1 09-30-2007 07:36 PM
Auto Sinks Justin1635 Plumbing 4 11-10-2006 07:00 AM
