#1 |
Two questions on Kenmore new Water heater.
Just got a new Kenmore's 50 Gallon, natural gas water heater. I have two
questions before installation: 1. The nipples coming with it have heat trapping function, but one end of each one (with two rubber baffles) has much smaller internal diameter. It measures smaller than 1/2". The connecting pipe is 3/4". See photo: http://i27.photobucket.com/albums/c2...u/IMG_0578.jpg Also, on the water heater cold inlet. the dip pipe seems to have the same (<1/2") diameter. My question is: will this reduce the hot water flow? I don't want shower becomes cold when another faucet for hot water is turned on. 2. The TP valve opening is not pointing straight down. It has like 5 degree angle passed the vertical line. Should I tighten it (need almost a circle) or loose it a bit to make it point straight down? Or, should take it out and redo it? Thanks, SZ |
#2 |
If the narrowest point is half inch then it seems to me it will reduce the flow. Although I don't see how they could get away with making a product with essentially a half inch outlet?
As for the T&P valve, just loosen it a hair, they never come aligned. |
#3 |
I checked some other brand water heaters and it seems that the dip stick at
the cold inlet needs to be removable from the hole. Therefore, its O.D. needs to be smaller than the I.D. of the tank inlet. Thus, the hole in the dip stick needs to be very small, probably smaller than 1/2" for all such type of WH. I suppose it is the way it works. The smaller hole in the nipple does not matter anymore. Thanks for the suggestion of adjusting the T&P. I just want to make sure it won't cause any leak by turning it with half-dried dope in there. SZ Last edited by sz8; 10-02-2007 at 01:59 PM. |
| Display Modes | |
| Electric Water Heater | GTSRider | Plumbing | 31 | 12-07-2008 12:30 PM |
| No Expansion Tank for Water Heater | vasanvasan | Plumbing | 4 | 12-14-2007 12:16 AM |
| Gravity Hot Water Recirculating Loop Questions | harleysilo | Plumbing | 2 | 02-06-2007 04:28 PM |
| Periodic release from (I think) the T&P valve on the water heater | alexz | Plumbing | 3 | 08-15-2006 11:31 AM |
| Draining a hot water heater | singforsupper | Plumbing | 1 | 06-07-2006 07:01 PM |
