Two Piece Tub/surround Unlevel - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2013, 04:25 AM   #1
Question
Two piece tub/surround unlevel
Hi... new here... I know what the issue is, but am looking for ideas in how to deal with it.
About 12yrs ago we had the bathroom redone - we gutted to studs and had a plumber install a new fiberglass tub/surround. It has a seam where the two pieces meet.
Y'all know where I'm going right?
Clearly the tub is installed unlevel sideways - the water runs along the seam, into the drywall - mainly at the drain end.
I've dug out the loads of caulking the now ex hubby stuffed in there, water seems to get behind it and run along the seam anyway. Plastic Qtip sticks stuffed into the seam diverts the water for a while. (yes, that desperate!)
There's a moulded shelf/grab bar built into the side, and that mould pattern seems to almost go down to the seam. So sticking "tub grout tape" along won't work - it can't handle the curves.
Any suggestions on something I can use to seal that seam, or deflect water from running along it like a channel?
mamadukes is offline   Reply With Quote
Old 01-14-2013, 05:33 AM   #2
DIY staff
Rewards Points: 7,174
Is it safe to assume you aren't planning to pull this out and re-do the thing?
Some sort of picture is going to be needed---I think to temporary fix could be done with silicone caulk ---but I need more info---
Old 01-14-2013, 08:33 AM   #3
Roofmaster
Rewards Points: 2,210
Yes, Pictures would really help. Sounds like you need a Z flashing to redirect water into the tub, but we need pics.
Old 01-14-2013, 03:05 PM   #4
Pics... yeah...
I'll try to take pictures and find a teenager around here to load them for me.
Caulking the seam still allows the water to run along it and out of the tub, into the wall.
And... a total rip out re/do is out of the question right now. Even if I pulled the tub surround out, the tub itself is just unlevel enough that the water will run along and out.
Old 01-14-2013, 05:46 PM   #5
Rewards Points: 582
well sorry to say 2 wrongs don't make it right...unit needs to be pulled to fix it right....if it was put in unlevel my guess it was not set in cement as it should have been which means it can come out fairly easy cleaned up and reinstalled..ben sr..again sorry
Old 01-14-2013, 10:34 PM   #6
It's set in a bed of something - looked like some sort of cement or plaster. I think they just didn't set it level, or somehow knocked it off level when they set the surround in.
I'll figure out a way to "mickey" it for the time being - even if I have to make a caulk "dam" to lead the water back into the tub.
Screw holes in vinyl siding piece due to awning removal - fill or replace? mark2741 Building & Construction 9 03-24-2011 12:21 AM
Can someone identify this piece? igendreau Plumbing 2 03-10-2011 10:35 PM
Interior door trim without enough space for a whole piece Dianna Carpentry 2 05-17-2010 11:09 AM
piece of horizontal wood through studs? yummy mummy Remodeling 13 11-24-2006 07:33 AM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 10:12 AM
