Two Part Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2014, 11:04 AM   #1
Rewards Points: 83
Two part question
Running a up flush into the basement. I can not really run a vent pipe straight up into the attic. I have to run it up obviously to the first floor then a 90 degree turn about12 feet to meet up with a current toilet vent. Here is where I have some choices. I can cut apart the connection at the toilet vent where it meets right under the toilet. Or I'll have to do another 90 degree and follow the current vent into the attic and then tie into the attic.
Now will it be an issue to run that vent horizontal for about 12 feet. And have 2-3 90 degree turns into it.
Second the current vent Im looking into tieing into vents into the attic. I have two vents in the house one goes outside from the master and the vent I just spoke of which is a half bath goes into the attic with a black gas vent cap on it. Doesn't seem to sink and didn't see any signs of moisture. But if I tie into this went it will go from a sink and toilet to two toilets, two sinks and a shower.
nards444 is offline   Reply With Quote
Old 02-24-2014, 01:34 PM   #2
Not by Code, you can't.
Yes...do that.
Not an issue.
That's called an AAV (Air Admittance Valve) - a "mechanical vent". It may not work with the ejector because it may not let in enough air to keep up with the ejector pump. You'd be better off extending that vent through the roof.
Ishmael is offline   Reply With Quote
Old 02-24-2014, 02:14 PM   #3
Rewards Points: 83
Hey thanks. I figured it wouldn't be to code, but my biggest concern would be if it works. once the job is complete it will be buried and nothing somebody is going to notice.
Now on that vent that's into the attic this is whats on it http://www.zorotools.com/g/00071173/...FYpaMgodWjcAEA
Venting into the attic is code from what I gather as I looked back at the home inspection and that was covered.
Now if I take that cap off and just put a 90 degree downturn elbow that should work as I have seen that. Don't get me wrong I don't like venting into the attic and will eventually get through the roof with it, as a temp thing It should be ok to just open it up as I explained
Old 02-24-2014, 02:25 PM   #4
It depends on your local code. I'm in MA, and AAV's (like the one pictured in your link) are not allowed without special permission from the state Board (and they almost never grant that permission). Some states allow them pretty freely, it seems. I also can't recommend leaving an open vent pipe in the attic. I'd rather add a 2nd AAV to the top of the stack before I did that - and only as a temporary thing until I put it up through the roof.
Edited to add: The vent for the ejector should be minimum 2" diameter from the basin all the way through the roof.
Old 02-24-2014, 02:39 PM   #5
Rewards Points: 83
Ok thanks. Thanks for clearing things up and confirming some of my thoughts. Yeah I don't like leaving a vent in an attic like that either. So Ill run my 2in vent up and over and every time I put a 90 or 45 in Ill ensure it runs up at lest a little. Once I get into the attic, Ill combine the two and up and out through the roof. Thanks
Old 02-24-2014, 07:02 PM   #6
Rewards Points: 1,854
Actually that black thing he pictured is not legal in any code. It's a mechanical vent with a spring. Commonly called a cheater vent. Air Admittance Valves have no springs.
Old 02-24-2014, 08:36 PM   #7
Interesting. Since they're illegal here and I don't use them, I've never seen any design/type other than that particular one. I had to google it to see what you're talking about. Still Mickey Mouse either way.
Old 02-25-2014, 09:46 AM   #8
Rewards Points: 83
Nothing mechanical no springs no nothing. Just a cap with the holes on the sides.
Its definitely mickey mouse and I dont like it and it will be going throught he roof when get to finishing it.
Delta tub spout question natwin Plumbing 19 02-17-2013 01:23 PM
two part central A/C question fred54 HVAC 5 03-22-2012 07:57 PM
Dishwasher Question: Any idea what this part is called and where I might can find it? Shpigford Appliances 1 07-23-2009 06:12 AM
Rafter question mrmarkyt Building & Construction 4 04-08-2009 09:19 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
