Old 07-30-2012, 12:36 PM   #1
Two Hole Strapping For CSST
My inspector says I need to strap my CSST with "two hole straps"
Can someone show me a picture of this so I know exactly what to get?
Thanks!
hellonoko is offline   Reply With Quote
Old 07-30-2012, 01:08 PM   #2
Ok, so what's a CSST?
Old 07-30-2012, 01:13 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
I know what it is. If you had to ask, it helps to answer your question, that it has been discussed on here time and time again.
For the OP, it looks like a C with two flats on the ends, so that you can secure it with a screw or two screws.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 07-30-2012, 03:15 PM   #4
@joecaption
http://en.wikipedia.org/wiki/Corruga...s_steel_tubing
https://www.google.com/search?q=csst...O8PgrAGZ8IDIDg
@gregzoll
Thanks, I just wanted to make sure it was not some special kind made just for CSST.
Old 07-30-2012, 04:08 PM   #5
gregzoll's Avatar
You never know with some of the AHJ's. Some are worst than others.
Tags
gas, strapping
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 12:55 PM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 07:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 03:52 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 10:57 AM
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General Discussion 2 01-01-2010 11:06 AM
