Two Handle Shower Faucet To Single Handle - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2008, 10:25 PM   #1
two handle shower faucet to single handle
i have a 1999 manufactured home.ive taken out the shower and was wondering if its possible to put in a single handle shower faucet since the water lines are pvc pipe?
GLASSMAN1 is offline   Reply With Quote
Old 01-31-2008, 02:06 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
The water lines must be CPVC, since PVC can only be used for cold water or drain lines, and not hot water lines.
Yes, you can switch to a single handle faucet from a dual handle. Go to a plumbing supply place that offers them with a large estuchion that allows replacement from the shower side, and will cover the dual handle holes.
Good Luck!
Mike Swearingen is offline   Reply With Quote
Old 01-31-2008, 08:08 AM   #3
Thanks Mike,i Just Wanted To Know If It Was Possible.ive Already Tore Existing Fiberglass Surround Out And Am Going To Put Shower Base And Tile?when I Put Backer Board Up I Should Be Able To Cut Holes To Match Plumbing.
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 25 01-26-2014 05:31 PM
Can't unscrew shower faucet jahanzebkhan Plumbing 11 12-29-2007 01:17 PM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 09:36 AM
3 handle shower epolgar Plumbing 1 08-13-2007 09:02 AM
Symons shower faucet ptedone Plumbing 2 01-01-2007 10:03 PM
